Struggles to start
Old Apr 23, 2024 | 06:38 PM
Extinct's Avatar
Easier to just put a FP gauge on it, Oreilly has one you can borrow.
Old Apr 24, 2024 | 12:16 PM
Joemama's Avatar
Haven’t had the chance to take a look at it yet, I plan to tomorrow.
I read in the RAVE I’m looking for 3.5bars. This should be instant 3.5 bars to the rail for priming before start up correct?
Old Apr 26, 2024 | 12:22 PM
Joemama's Avatar
Just checked the fuel pressure at the rail. I basically had zero pressure. Fuel pump it is. Thanks for all the help.
Old Apr 26, 2024 | 07:39 PM
Harvlr's Avatar
Have you made sure that your inertia switch isn’t tripped? Fuel pump is a very likely suspect but checking the inertia switch is free.
Old Apr 26, 2024 | 09:47 PM
Joemama's Avatar
I didn’t check the intertia switch but I check the pressure side by side of a another disco in comparison.
0psi vs 80psi was very clear it’s a bad pump
Old Apr 29, 2024 | 08:09 AM
mollusc's Avatar
But if your inertia switch is tripped you will have zero fuel pressure.
Old Apr 29, 2024 | 08:58 AM
sqlbullet's Avatar
I am with mollusc...Check the interial switch before you dig into the pump. If that switch get's tripped, it's job is to stop power to the fuel pump. It's super easy to access (as opposed to other vehicles I own), take you two seconds to press to reset.
Old Apr 29, 2024 | 11:03 PM
Joemama's Avatar
Originally Posted by sqlbullet
I am with mollusc...Check the interial switch before you dig into the pump. If that switch get's tripped, its job is to stop power to the fuel pump. It's super easy to access (as opposed to other vehicles I own), take you two seconds to press to reset.
I honestly didn’t know that! The more you know. I ultimately just thought zero pressure meant the pump was out.
I will try to find out to reset it and do it.
Old Apr 30, 2024 | 08:09 AM
mollusc's Avatar
Passenger side firewall. Push the button. That's it.
Old Apr 30, 2024 | 08:30 AM
sqlbullet's Avatar
This thread has an image with the inertia switch circled in green in the top left of the engine bay.
https://landroverforums.com/forum/fo...scovery-63621/
