Stubborn Fan
Old Jul 23, 2024 | 03:24 PM
mollusc's Avatar
The radiator from my parts truck is a Nissin in excellent shape. Everything seems good so far, but I want to switch to a 180F thermostat. I have two of them but whenever I install either of them the temps start to go crazy like they're not opening. I need to check them in hot water.
Old Jul 23, 2024 | 05:29 PM
mln01's Avatar
When I drain and refill the coolant, observing carefully the bleeding instructions in the RAVE, the temp spikes to 220 or so for under a minute on the test drive, then comes down to where it should be. A minute at 220 or so won't cook the headgaskets. I don't know how long you let it run with it "overheating", but you might want to let it run a little longer to see if the temps come down as they did on my truck. And drive it after start up; don't just leave it to idle. Just sayin' ...
Old Jul 23, 2024 | 05:40 PM
mollusc's Avatar
This was while driving, about 10 minutes in. Went up to nearly 150. Not fun.
Has been stable since putting the 195 thermostat back in.
Old Jul 26, 2024 | 08:12 AM
nashvegas's Avatar
The temp overshoot on initial warm up, then settling back down to normal ... is a classic symptom of thermostat opening too late ... or a thermostat that's not working properly... Did you replace the t-stat?
Old Jul 26, 2024 | 11:49 AM
mollusc's Avatar
As stated, I tried two different 180F thermostats. One that I had used last year, and one new out of the box. Same behaviour with both. I'm going to test them.
Old Sep 23, 2024 | 07:54 AM
huggi's Avatar
An update on temps. Driving around Midwest temps in the 90s AC on I haven't gone over 186. Flowkooler with new fan clutch and fan definitely worth it. Fan is much louder though.
Old Sep 23, 2024 | 09:49 AM
Harvlr's Avatar
Thanks for updating us.
me 2
Jul 14, 2022 07:02 PM
gecko951
Mar 5, 2022 10:17 AM
arains44
Jun 19, 2020 09:48 AM
KingKoopa
Jun 8, 2017 07:48 PM
Savannah Buzz
Mar 11, 2015 04:22 PM
