Stubborn Hub
Yeah I thought I had hub issues with the Alveston and even with pullers like these to separate the half shaft from the hub, I said heck with it and just got new half shafts and hubs.
I put up with that on one side. When I just replaced both, it was a legit 20 minutes to do the R&R. Suffice it to say, I probably went through a tube of anti seize for the installation of the new parts.
Now this is different than your situation as you were just trying to get the hub off the axle assembly, but in my opinion. Taking it all off and just replacing both is worth the minimal added cost.
After watching some videos, I may at some point get nuts on the Giverny and even gear it (if we stay put for a while so I can get it to the state I’d like for general use) as I’ve watched a couple videos, and doing gears doesn’t seem too difficult and definitely doable on a bench.
