Stuck caliper causing 3 amigos?
Old Mar 5, 2013 | 02:39 PM
br0keit's Avatar
Default Stuck caliper causing 3 amigos?
For a while I would get very random 3 amigos. It seemed that only when it was wet they would come on (like sitting at a stop light and pop on). Immediately after restarting they'd go away. This would happen once every 2 weeks at most.
The other day they came on and didn't turn off when I restarted as usual. I then noticed a slight grinding noise when coming to a stop and for a second or 2 after taking off. I also noticed a "burning clutch" smell when getting out of my truck around the same time. I passed it off as being another nearby vehicle as it wasn't strong and went away fast. I can only assume I was burning off my brake pad and now I have a stuck (probably over extended) caliper rubbing metal to metal causing the grinding.
I don't have a scanner yet though I may rob ZGPhoto's house for one here shortly...
Would it be possible for a stuck caliper to cause 3 amigos to stay on permanently?
Old Mar 5, 2013 | 05:33 PM
Grinding sound would most likely be your pads are metal to metal and yes it will trip the 3 amigos.
Old Mar 5, 2013 | 08:05 PM
ZGPhoto's Avatar
Haha please don't rob me... If you need a scanner I can work something out.
Old Mar 5, 2013 | 11:34 PM
br0keit's Avatar
Ha...don't need a scanner yet...we'll see what a full brake job does first. I really hope the caliper isn't beyond an easy rebuild.
Old Mar 6, 2013 | 07:56 AM
ZGPhoto's Avatar
We have new ones for around $80 if you're not enjoying the rebuild haha.
ImQuattro
May 1, 2014 08:36 PM
vandal996
Feb 17, 2011 09:44 AM
spjcarter
Nov 21, 2010 03:51 PM
rebooTT
Jun 20, 2005 01:09 AM
