Stuck in Park
Old Dec 20, 2010 | 04:33 PM
Oldtightloops's Avatar
Default Stuck in Park
I have an 01 Disco II with 130K miles. No prior transmission work. Occasionally when I try to get it out of Park, the shifter won't budge. If I release the brake pedal and then press it down again, it will usually release the shift lever. Is this in the brake system or the shift lever? And, any idea of the cost to fix it?
Old Dec 20, 2010 | 07:26 PM
Buy 2 and keep one in the glove box as a spare.
It will take you a small flat blade screw driver and 2 mins to replace it.
http://www.roverparts.com/Parts/XKB000010G.cfm
You can also buy it locally at a autoparts store or the dealer.
It attaches to the back of the brake pedal.
Old Dec 21, 2010 | 07:35 AM
Default Thanks Spike!
Thanks for the help. Merry Christmas!
Old Dec 21, 2010 | 11:32 AM
frankieoboy's Avatar
OK, let's say you're stuck without a replacement switch or with a solenoid that dont respond, can you easily block the solenoid out of the way or remove it ?
Frankie
Old Dec 21, 2010 | 12:39 PM
DaveBFoto's Avatar
Yeah, just pry up the plastic housing around your shifter with a knife or a screwdriver. There's a small metal pin keeping the shifter from coming out of park, just push it out of the way and shift out. Go straight home or to a rover shop though, because if the switch is out you won't have brake lights, and nothing's going to ruin your day like getting rear-ended over a 30 dollar part!
Old Dec 21, 2010 | 01:02 PM
oysterhead's Avatar
is it really necessary to replace the harness?
or just the switch?
Old Dec 21, 2010 | 05:59 PM
or just the switch?
I do not know.
I would imagine just the switch, thats how it is on a DI and how it was on my wifes Volvo.
But on her Volvo even though we had no brake lights we could still shift out of park.
Old Dec 21, 2010 | 06:01 PM
Frankie
I have heard but cannot confirm that you can turn on the rear defroster and that will allow you to shift out of park with a bad brake light switch.
But again, I have NO idea.
Old Dec 22, 2010 | 06:11 AM
Rovin4life's Avatar
yes you need the harness. its an updated part that they borrowed from an lr3. so the jumper harness fits with the other part.
amer_qureshi
Jul 10, 2024 02:03 PM
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
felixx23
Jun 2, 2005 12:05 AM
