STUCK IN PARK.....AGAIN!!!
Old Sep 20, 2008 | 07:01 PM
ericandersontn's Avatar
Default STUCK IN PARK.....AGAIN!!!
I have a 2000 Discovery Series II. The car is currently stuck in park and will not go into reverse, neutral, drive, anything. It simply wont come out of park. This has happened to me once before and I paid to have it towed to Land Rover and although the bill wasn't that much....like 200 bucks i think....I was wondering if their was any way I can get it out of park without having to tow it. When I took it their last time they said it was a sloenoid valve or something???? I was wondering if anyone could help me on how i could maybe get it to where i can at least drive it? Thanks.
Old Sep 20, 2008 | 08:06 PM
Different Drummer's Avatar
Default RE: STUCK IN PARK.....AGAIN!!!
Could this be the dreaded brake light switch problem that I've read about? The ability toshift out of park is apparently tied to the brake light switch under the brake pedal so you can't shift out of park without your foot being on the brake. I've read of some people who carry an extra brake light switch in their glove compartment just in case this happens.
Old Sep 20, 2008 | 08:47 PM
I thought that could be it too however when i push the brake both brake lights light up so its not the brake switch i dont think.
Old Sep 20, 2008 | 11:26 PM
jsh's Avatar
jsh
4wd High
I had this problem in my 96 discovery and it turned out to be small retaining clip had jammed in the shifter **** (preventing the shaft from moving up and disengaging)
I searched this site and found this problem was common to someone else and moved quickly with the fix
john
Old Sep 21, 2008 | 09:04 AM
Or it can be the solenoid that releases the tranny.
Old Sep 21, 2008 | 01:30 PM
Buy and install a new brake light switch and keep the old one. They are fairly cheap and it is a good place to start.
http://www.roverparts.com/Parts/XKB000010.cfm
Sounds like the dealer didnt fix it they just diagnoised it and told you what was wrong.
Check your reciept,IF they replaced a part then that part is under warrenty if less than 12 month or 12,000 miles.
amer_qureshi
Jul 10, 2024 02:03 PM
abran
Jun 30, 2014 12:43 PM
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
