Stupid Strupid ATF question... Dexron III Vs IV?
Old May 4, 2010 | 06:47 PM
Originally Posted by Rover_Hokie
Can you not have the other side of where you pull the line to pull in fresh new ATF from a container while the rover thinks it is circulating the old ATF? When you see the new fluid coming out you shut it down and you are not all full of new ATF. Wouldn't that work if you can get the break in the line in the right place and set up the hoses correctly? Maybe a little difficult to break into the line in the right place and have it work, but in theory wouldn't this work?
Thats is exactly what they do when you have a tranny flush done at the quick lube or the dealer.
Only they have a machine to collect and replace the fluid.
Old May 4, 2010 | 06:52 PM
lipadj46's Avatar
Yes you are describing the proper way of doing an ATF flush/exchange except you just pull the lines off the ATF cooler.
Scott Weiland
Jul 11, 2013 10:05 AM
greenharoguy
Feb 19, 2013 08:52 PM
bigbalu
Feb 12, 2013 11:07 PM
humroot
Mar 12, 2010 06:31 PM
llPANCHOll
Feb 1, 2009 09:47 AM
