..:: The Sudden Not Starting Situation ::..
Old 11-01-2021, 12:06 PM
adolfojbonilla's Avatar
Originally Posted by mollusc
They're usually all over eBay.
Make sure that you get the correct one for your model year. The 1999-2002 boxes are different from the later ones.
Thanks for the input MOLLUSC, that's where I first started with no luck yet, but still waiting on some replies there. Yes, gotta find the right one, since besides the year difference, they also are dependent on with or without SAI pump. Thanks again.
  #82
Old 11-01-2021, 12:34 PM
whowa004's Avatar
Will Tillery or other breakers on FB, Roadside Werx or other indy rover shops might have some.
adolfojbonilla (11-01-2021)
  #83
Old 11-01-2021, 01:52 PM
...thanks WHOWA004 ...do I find these two people on FB by searching those names? let me know, thanks.
  #84
Old 11-01-2021, 03:22 PM
whowa004's Avatar
  #85
Old 11-17-2021, 06:39 AM
Hello Roverers! I'm happy to report that after taking the YQE103830 fuse box pulled from donor Disco in junkyard, my mechanic called me yesterday afternoon to say the it was running just fine. That they've taking it for few rides and errands with no issues whatsoever, and was confident for me to take it home, so I'll be going there this morning to pick it up and test it myself. Fingers crossed the issue has been solved. I'll be reporting back. Thanks to everyone and each of you for your suggestions and recommendations during this ordeal, very glad to be part of this family of LR owners! ;-]#
matt3502 (11-17-2021)
  #86
Old 11-30-2021, 10:46 PM
m_lars's Avatar
My 03 ran out of gas about two seconds after the low fuel light popped on and needle above red by a 1/16 of an inch. Had code reader hooked up when it died, checked them...because..."it couldn't be out of fuel"...bunch of misfire codes. Cranked over strong and never tried to start.
Dumped five gallons in it and drove home...
On the D2 the low fuel light is actually a "you're too late" light!
  #87
Old 12-01-2021, 08:07 AM
...in my case the issues ended up being much more than just adding more fuel. At least on my Disco, once low fuel light comes on, I've ran as far as 30-somethin' miles 'till it has died on me, but I try to run as far as 25 to be safe. Is always good to know how far you can drive once it lights up. Be safe out there.
upstateNY
11-05-2014 11:41 PM
Phatrowles
08-12-2013 12:15 AM
liljhon
12-27-2012 05:20 PM
JBEGIN
03-18-2011 08:41 AM
Doral300sc
02-25-2006 11:32 PM
Quick Reply: ..:: The Sudden Not Starting Situation ::..
