SunRoof
Old Jul 10, 2013 | 09:02 PM
slabrat's Avatar
Default SunRoof
Ok after I stressed over how to stop the sunroof leak, I took the glass off and removed the gasket.( found a loose screw holding the glass. I cleaned everything; rails, tracks,glass,etc.Cleaned the gasket and lubricated it with silicone lube. Put it all back together ,measured (rave) the distance from front of glass to rail. It rained hard today and no leak. Hope this got it. If your sunroof leaks check the torx bolts to see if they are loose and lube the gasket. This MAY stop it
Also Greased the rails and it operates much smoother. Love the 99
BigRed98
Jun 21, 2010 12:30 AM
opus13
May 18, 2006 05:07 AM
Durfee
May 11, 2006 04:50 PM
Jesse
Mar 2, 2006 01:53 PM
funkeruski
Aug 22, 2005 02:26 PM
