Sunroof Banging
Old May 10, 2006 | 11:40 AM
Durfee's Avatar
Default Sunroof Banging
My front sunroof in my 2000 Disco bangs every time i go over a sizable bump in the road. Any hints. are there pads that need to be there and are not?
Old May 10, 2006 | 12:38 PM
Default RE: Sunroof Banging
Does this happen with the sun roof open, closed and in to up position? If it is only in the closed position, have you looked at the sun roof from up top to make sure it is locking down all the way closed?
Mike
Mike
Old May 10, 2006 | 01:42 PM
NHESS81's Avatar
Mine will vibrate and shake if the road is crummy enough....this is a 97 D1, with it fully open...when closed or cracked it does not make the sound. I am guessing there isnt really anything I can do other than try to take it apart and shim up some gaps--way too much work for just a little rattling...
Old May 11, 2006 | 11:21 AM
Durfee's Avatar
It only happens when it is open other than that it fine
Old May 11, 2006 | 04:50 PM
ORIGINAL: Durfee
Sounds like when it opens, it is not fully open and locked. You might want to compare the front to the rear and see if one goes back farther.
Mike
Freedom38
Jun 26, 2015 10:37 PM
phurie
Aug 13, 2012 08:05 AM
MandyDarren
Freelander
Aug 2, 2011 08:43 PM
sullyg
Freelander
Feb 19, 2008 01:31 PM
Tim444
Mar 13, 2006 11:17 PM
