Freelander Talk about the Land Rover Freelander within.
Freelander 2001 banging noise
Old Jun 19, 2007 | 03:48 PM
sullyg's Avatar
Default Freelander 2001 banging noise
I hope you will have an answer the the bumping noise in my 2001 1.8s Frelander.
We have replaced the two mounts on the drive shaft and around the diff but there is still a loud bumping noise at low speeds from 5mph to 15 mph then it goes away untill you go back down to these speeds it is comming from the middle of the car. Stumped us please advise
Gary
Old Nov 30, 2007 | 05:32 PM
redsfan54321's Avatar
6th Gear
Default RE: Freelander 2001 banging noise
When my 2001 1.8 was making aknocking noise after changing gear i got a mechanic to look at it and he said it was just a loose bush.
Old Feb 19, 2008 | 01:31 PM
Blippie's Avatar
The main candidates for thumping like this arethe VCU mounts (especially aclunk from the middle of the car when changing gear) and the front/centre mount of the three on the rear diff (especially a thump from the rear of the car when taking sharp, slow corners or speed bumps).
Bothe are reasonably easy jobs for the amateur mechanic.
If you have these exchanged you need to investigate by getting under the car, grasping the propshaft and twisting it. Is therewear in the UJs? Give the propshaft a jolly god up-and-down and side-to-side? Are the five bushes/mounts mentioned disintergrated or worn? Some perishing of the rubber is ok, but poor quality bushes can fall apart.
Cheers
Blippie
Cheers
Blippie
Freedom38
Jun 26, 2015 10:37 PM
phurie
Aug 13, 2012 08:05 AM
MandyDarren
Freelander
Aug 2, 2011 08:43 PM
Durfee
May 11, 2006 04:50 PM
Tim444
Mar 13, 2006 11:17 PM
