Sunroof drain tubes
Old Sep 1, 2025 | 07:19 AM
ewbourne's Avatar
Default Sunroof drain tubes
Is this where the front sunroof drain tubes are supposed to drain from and if so how can I access it?
Old Sep 1, 2025 | 07:38 PM
CharminULTRA's Avatar
The sunroofs drain into an inaccessible area inside of the body, behind the front tires. At least I wasn't able to see any way to access this area. What are you trying to accomplish?
Old Sep 5, 2025 | 07:40 AM
redrover75's Avatar
The front ones drain up by the transmission. further back and on the drivers side if i recall. I dont have a photo. But if you get under there with a light you can see a rubber nipple that has a cross cut in it. If you squeeze it, it will open and drain down your arm. I cut one of the four flaps/valves off to help it drain and keep from getting plugged up again.
Old Sep 5, 2025 | 10:48 AM
Brandon318's Avatar
Aye, those are the A/C drain lines actually.
Old Sep 5, 2025 | 10:51 AM
Brandon318's Avatar
They can be accessed I believe by removing the wheel liner there. You can use fiberglass fish tape to reroute them through the a-pillar if needed. Done before, wasn't that difficult with someone's help.
mpnesi72
Mar 24, 2025 03:43 PM
Jdyer1960
LR4
Mar 2, 2025 10:47 PM
nashvegas
Oct 16, 2023 02:38 PM
sputnik62
May 28, 2018 10:50 AM
Gerard
Feb 20, 2011 06:54 PM
