Sunroof drain tubes
The front ones drain up by the transmission. further back and on the drivers side if i recall. I dont have a photo. But if you get under there with a light you can see a rubber nipple that has a cross cut in it. If you squeeze it, it will open and drain down your arm. I cut one of the four flaps/valves off to help it drain and keep from getting plugged up again.
They can be accessed I believe by removing the wheel liner there. You can use fiberglass fish tape to reroute them through the a-pillar if needed. Done before, wasn't that difficult with someone's help.
