Sunroof reseal tips
Old Jan 31, 2017 | 05:35 PM
Crisis In My Nomex's Avatar
https://www.amazon.com/3M-08609-Wind.../dp/B000FW61EW
Would this be a better adhesive? I've used it on 3 piece wheels, and it's nearly impossible to remove.
Old Jan 31, 2017 | 07:26 PM
number9's Avatar
􀁺 Fast Cure
􀁺 10-15 Minute Work Time
I would look for something else. But I'm old, slow and ****.
Old Jan 31, 2017 | 08:02 PM
Twix's Avatar
I thought about taping off most of the glass and masking the rest of the truck and spraying bedliner on the whole roof to seal it up
Old Jan 31, 2017 | 08:57 PM
Luckyjayb's Avatar
since I have repaired mine, that's my game plane. Remove the plastic drip rails and have it linex'd and trace them wrap under the drip rails that way it will seal forever and you won't see it the much with a roof rack
Old Feb 3, 2017 | 01:02 PM
OffroadFrance's Avatar
What I can never get to grips with is that they install climate control/aircon and double up with fitting one or even two sunroofs, nuts to me it seems unless you have pets locked in the truck, which you shouldn't have on hot days.
I am using the reflective insulation for a couple of reasons, firstly it's thin and secondly to reduce the heat ingress into the cab area through the roof on very hot days and to prevent the headliner glue breaking down once again. Hopefully it'll work well and if it don't I'll won't post that I've failed
Old Feb 3, 2017 | 01:06 PM
[QUOTE=Crisis In My Nomex;594439]https://www.amazon.com/3M-08609-Wind.../dp/B000FW61EW
Nomex race wear I hated years ago, when I sweated it made me itch like crazy in the summer, either the heat, adrenaline or the nerves or both
Old Feb 6, 2017 | 12:49 AM
Jeff Blake's Avatar
I plan on tackling this soon... tired of having a tarp on my roof!
Depending on the condition of the seal, I think it might be a good idea to replace it. # EEQ500010
As for sealant, I was thinking a marine sealant like this? https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Old Feb 6, 2017 | 01:18 AM
number9's Avatar
Much preferable to silicone based IMHO and from experience. 3M has a few other non-silicone marine sealants available and in other colors too. A couple of other companies also have polyurethane or polysulfide sealants available that are worthwhile taking a look at. Considering the amount of labor involved might as well use the best materials available. 2-part polysulfide sealants are widely used in the airline industry.
Old Feb 6, 2017 | 11:03 AM
Motorhead1's Avatar
Getting our first rain since I resealed the rear sunroof, no leaks. Now I need to tackle the front unit (leaky drain) and get the damn headliner back in...Of course while I've had the headliner out for the last few months, I came up with all these great plans of removing the factory roof bars that serve zero purpose, build my own low profile roof rack, pre-running electrical for roof rack lights and cb stuff....who knows
Old Feb 6, 2017 | 04:00 PM
Great result
On the plastic drain well attached to the sunroof perimeter, sand it well, degrease it and use viscous epoxy filler all over and bonded well to the metal frame. After it's cured overnight in a warm place, paint it with a black bitumen paint and let it dry thoroughly.
Stick an airline down the drain tube at the top and blow through GENTLY or you'll blow the tube to pieces or dislodge it, then you're buggered.
RedRovin'
Mar 11, 2016 06:40 AM
damygoliath
Oct 2, 2013 09:18 AM
kpl1228
Dec 5, 2010 01:38 PM
discoboy
Dec 30, 2009 11:46 PM
jwood700
Nov 21, 2009 10:26 AM
