sunroof sticking clackety clack
Old Aug 11, 2009 | 01:40 PM
98roverguy's Avatar
Originally Posted by Suede
I 2nd this. When you look in the track on both sides, you can clearly see where the play is. Just press on some new o rings to take up the slack from the old worn ones. I did this on both the front and rear sunroofs and have not had any problems since. Oddly, it was the passenger side bushing that was worn on both sunroofs. Out of silly curiosity, were all your bushings worn, or just on one side like mine?
Yup. Front passenger side. Interesting. The rear sunroof still has the original clips and works fine. I do actually use my sunroofs often during the spring/summer/fall months. I very much enjoy them. So that was a must fix. I think these clips can break easily if your roof is open and your going over some rough terrain.
I think the rubber o-rings are actually a better replacement, as they absorb the shock better than brittle plastic. Just make sure they are lubed up well and watch them glide on the track a few times to make sure they are properly seated around that stub thingimijig...
Glad to hear it has worked for you as well!
Tony Luna
Apr 28, 2015 12:31 AM
BigRed98
Jun 21, 2010 12:30 AM
apcollin
Aug 6, 2008 08:32 PM
tsuami1
Jun 20, 2008 07:53 PM
GeorgeD
May 19, 2008 07:31 AM
