Suspension bolt kit
Old Apr 26, 2026 | 03:17 AM
Brando04's Avatar
Default Suspension bolt kit
I’m looking to replace all suspension bushings, tie rod, watts linkage drag bar Panhard everything and I’m reading that I should run new bolts and nuts..ab sells one radius arm bolt for 19 dollars..is there anywhere I can get a full set cheaper? Or can I run full thread bolts on the radius arms?
thank you!!
Old Apr 26, 2026 | 07:02 PM
Extinct's Avatar
You cannot, those bolts are specially sized to not only fit the radius arms but also the mounts. They are stepped where they go through the frame. I installed one the wrong direction once and it clunked until I changed the other way.
Old Apr 27, 2026 | 12:07 AM
Brando04's Avatar
Oh okay these look like them and are only 6 you think they’d work? M16 1.5 100mm partially threaded
https://metricspecialties.com/produc...55236569596273
Old Apr 27, 2026 | 04:47 AM
Extinct's Avatar
No, I am telling you that the bolts is a specially engineered to fit bolt. Those will work, but you will have a clunk in the suspension due to excessive clearance. Why do you want to replace the bolts? They don't wear. Just re-use existing and save your money to get other parts/gear.
Old Apr 28, 2026 | 11:54 AM
mln01's Avatar
thank you!!
Why did you decide to do this?
Old Apr 28, 2026 | 12:17 PM
Brando04's Avatar
because I’m replacing everything…bushings are worked so might as well…found a full set of bolts from gwynnlewis4x4
Old Yesterday | 11:55 PM
Brandon318's Avatar
I did this project last year as a little 200k refresh and reused the bolts. Although… it’s a CA truck so they still look factory new. If they were super rusty I might’ve replaced them.
I *did* however replace any nylock nuts I ran across.
Feels like a brand new Disco after all that work is completed.
CantComplain
Aug 21, 2022 08:14 PM
Nitrojunkie383
Apr 2, 2016 05:37 PM
pgoodrich
Feb 9, 2016 11:46 AM
coors
Jul 16, 2013 08:47 PM
batiscan
May 24, 2010 09:04 PM
