suspension deflated. now it's fine.
Old Apr 21, 2014 | 12:15 PM
sDot's Avatar
Default suspension deflated. now it's fine.
Twice already out of the blue while driving the left airbag starts leaking air. I hit a pothole over the weekend and lost air on the left side, which caused the right side to drop as well. This also happened 2 months ago as well.
Just trying to figure out if something is loose. I left it for an hour, came back and it inflated fine.
Any ideas?
Old Apr 21, 2014 | 12:21 PM
Dane!'s Avatar
They get leaks in the folds sometimes, maybe you hit the pot hole hard enough to expose a leak? Mostly leaks over time though if it would leak that much under a load.
Also, not sure if theres a pressure relief valve, if there is maybe it opened if you hit it hard.
Old Apr 21, 2014 | 02:19 PM
sDot's Avatar
Ahhh.. pressure release valve. Makes sense.
But can someone confirm if there is one, and if this issue would sounds plausible?
Old Apr 21, 2014 | 03:07 PM
OffroadFrance's Avatar
If there's an air leak it needs carefully checking out. If there is, the compressor will run continuously and finally burn out. If the compressor burns out that's serious $$$$$$$$ bucks to replace.
See the other thread on SLS air springs.
sn1987
Tires
Dec 30, 2009 11:11 AM
tomfraser
Mar 1, 2009 09:29 PM
RysRover
Aug 28, 2007 06:04 PM
Bene
Jan 29, 2007 12:59 AM
arrkerr
Dec 14, 2005 10:06 AM
