System functionality w/ 3 Amigos
Old Sep 14, 2019 | 03:13 PM
greisinb's Avatar
Default System functionality w/ 3 Amigos
When the 3 Amigos are illuminated are those systems totally off line? I recall reading that the ABS might function depending on the failure mode. Ultimately what I want to know is this: if one of my wheels looses traction will any systems intervene or will all of the torque flow through the open differentials to that wheel?
Old Sep 14, 2019 | 03:42 PM
Billfromthehill's Avatar
All torque will go to wheel with least traction
Old Sep 14, 2019 | 04:12 PM
greisinb's Avatar
This was my understanding as well, but another person mentioned having no problem when they were off roading and their 3 amigos lights had been on for quite some time. Is it possible the lights come on when a fault is detected but then if the fault goes away system functionality comes back but the lights stay on as a “sticky fault?”
Old Sep 14, 2019 | 05:40 PM
Best4x4's Avatar
No TC, no HDC, and I'm not really sure the ABS kicks in at all. Pull the codes and fix the amigos and enjoy a fully operational system IMHO. Option B, and new sensors normally fixes the 3 Amigo's for good. HDC off road is very handy and so is the TC.
Old Sep 14, 2019 | 07:50 PM
Bignacio's Avatar
I agree with Best4x4. A while back I was off roading and the 3 amigos came on. I didnt have TC or HDC. Later I replaced one abs sensor and did option B. No 3 amigos since then.
Old Sep 14, 2019 | 11:12 PM
greisinb's Avatar
I’m planning on fixing it before I put it in any position where it would be a big problem. Scanning the codes is my first priority, last time I took my other car to autozone the let me use what looked like a nice code reader so I’m going to try my luck there first to see if it will also pull ABS codes, if not I’ve got one in my amazon cart ready to pull the trigger on, but if I can save a $100 all the better (I already have a regular code scanner).
Old Sep 14, 2019 | 11:18 PM
Bignacio's Avatar
If you are in southern calif, I can loan you mine.
Old Sep 15, 2019 | 12:02 AM
greisinb's Avatar
Thanks for the offer Bignacio, but I’m up in Washington.
ihscouts
Jan 4, 2016 07:05 AM
ImQuattro
Jul 11, 2014 03:57 PM
bink1109
Nov 18, 2012 09:34 AM
wyrdvans
Oct 6, 2011 08:48 AM
jneil
Jan 2, 2011 11:42 AM
