T-case oil?
Old Jul 11, 2013 | 10:21 PM
blackpaw80's Avatar
Default T-case oil?
What oil are you guys using in your transfer case?
I live in Denver, where it can easily hit over 100 during the day, but when I'm camping in the mountains can still drop to 32F in August.
Old Jul 11, 2013 | 10:36 PM
bballjames's Avatar
85w140
Old Jul 11, 2013 | 10:39 PM
caymandrew's Avatar
+1 on 85w140 (tcase and diffs)
Old Jul 11, 2013 | 10:49 PM
blackpaw80's Avatar
Thanks.
Old Jul 12, 2013 | 12:14 AM
85W140 and some of this LUBEGARD Gear Fluid Supplement
Old Jul 12, 2013 | 07:31 AM
Use it in your diffs also.
Old Jul 12, 2013 | 10:41 AM
Jared Shively's Avatar
7th Gear
Is there a way to "top off" tcase oil? Or do you have to drain it all the way and then put in the recommended amount.. (7 quarts if I remember right)..
Old Jul 12, 2013 | 10:52 AM
ZGPhoto's Avatar
I've topped off before, but that was only temporary. No issues. Half inch fill plug.
Old Jul 12, 2013 | 11:04 AM
7th Gear
I guess my actual question is.. How do you know when the oil is 'topped off?' Is it like the transmission fluid where a small bead of oil comes out the top? I have filled it before and replaced all the gaskets but there still seems to be a little leak (like 5 drops a day)..
Old Jul 12, 2013 | 11:22 AM
caymandrew's Avatar
Yes, just open the fill plug, if you get a bead coming out it's full. If not, just fill until you do.
More info here: https://landroverforums.com/forum/di...ictures-27159/
kpl1228
Mar 26, 2011 06:19 PM
sailorcolin
Feb 21, 2008 05:08 PM
alex of minnesota
Dec 8, 2006 09:52 PM
Td5
Sep 1, 2006 05:01 PM
disco12
Mar 6, 2006 05:02 AM
