T case still leaking
Old May 22, 2019 | 12:48 PM
Jakerover's Avatar
Default T case still leaking
Title says the problem, resealed the T case, held for a few months and am still getting leaks from it at a similar rate any suggestions?
Old May 22, 2019 | 12:58 PM
Motorhead1's Avatar
Make sure the vent isn't clogged? Did you put thread sealer on the bolts that require it?
Old May 22, 2019 | 02:40 PM
FlyingZebra34's Avatar
Did you take the Tcase out and reseal all the gaskets? What failed? X2 on vent plugged.
Old May 23, 2019 | 12:36 AM
Discorama's Avatar
I had a plugged vent (melted), which seems to be pretty common. Get a piece of 1/4 ID hose which can be connected to the end of the vent line in the engine compartment. Try to blow air in with your mouth, there should be no resistance until some pressure builds up (like blowing up an air balloon), then release the end and some decent amount of air should be coming out quickly.
Sean Winter
Aug 13, 2017 06:08 PM
ls1morethanyou
Mar 23, 2015 12:51 PM
KlamathMatt
Oct 29, 2013 12:15 PM
merleti
Freelander
Sep 13, 2007 09:28 PM
