A/T tire shopping
Old Feb 10, 2016 | 10:39 PM
  #21
LR03NJ's Avatar
Originally Posted by 04disco2va
LR03NJ - What size tires do you have and what lift. Pics look good.
Thanks
04disco2va, Its a LT275/65R18 they are 32.1" dia. and OME springs and shocks 1.5" lift, No rubbing. They now have the 265/60R18 and only 30,5" dia. I am sure this will fit without a lift. I am planning to get those coz I dont want to lift my other disco. I ran over 80K miles on them and still have reasonable thread, likely because its 10ply.
Old Feb 11, 2016 | 11:17 AM
  #22
04disco2va's Avatar
LR03NJ - Thanks for the reply yesterday. Yes I really didn't want to do a lift. I ordered the duratrac's last night, but went with the 265/65-18. I wonder if should have gone with the 265/60.
Old Feb 11, 2016 | 04:42 PM
  #23
LR03NJ's Avatar
Hopefully it will fit without rubbing. The factory original is 29.00" diameter and you got a 31.5" replacement. Mine, right now is a 32.1" diameter and will fit without the OME 1.5" lift but I never tried without the lift coz I got the truck lifted first before purchasing the tires. So, for me its untested. Once you have yours installed, you will have a minimum of 1.25inch clearance on both ends of the fender. It will fit but I have no idea if it will rub once you turn or drive up a curb while turning.
I think I saw somewhere that if you add wheel spaces, it might eliminate some rubbing (or not) if it happens or the suspension spring spacers as well. I cant be technical about those, I just compensate by getting other upgrades so that the 1st upgrade will work. Anyway, I hope youll be happy with your new tires. Cheers!
motobene
Jun 20, 2017 01:27 PM
DiscoIIBrandon
May 11, 2011 11:04 PM
RoadWarrior
Feb 1, 2009 01:38 AM
Randall in NC
Dec 3, 2005 10:55 AM
Off Topic
Apr 14, 2005 08:15 PM
