Tail lights not working
Old Jul 24, 2012 | 01:25 PM
how about this one, about an 11 on the Rover Deal-o-Meter https://landroverforums.com/forum/ne...ew-girl-44500/
Old Jul 25, 2012 | 12:07 AM
toofaroffroad's Avatar
Default tail lights not working
OK, thanks for your patience. I did the meter test properly this time. 12v reading on both 11 and 33 when switch was turned once to engage parking and tail lights.
I did already order a turn signal switch, used for $25. Should have it in a couple days. If you've got any other ideas while i'm waiting please chime in. Thanks for any help.
Old Jul 25, 2012 | 04:34 AM
To replace the turn signal switch rotate wheel 90 degrees. But the turn signal switch does not control those tail light bulbs. It tells the BCU to flash the others. Have you checked the actual sockets for the bulbs, and the frame ground (black wire) to be sure it is good to the frame?
Old Jul 25, 2012 | 11:56 AM
Default tail lights no working
I have not checked the ground but remember it is both tail lights and both front parking lights that are not working. Wouldn't that be a huge coincidence if they all went bad at one time or can one effect the others?
Old Jul 25, 2012 | 05:12 PM
Well, one fuse drives one side of the truck, and the other fuse drives the other. They run through different cables to get to their destinations, and use different headers. The only thing "common" at the tail end is that both circuits also run into the trailer connector. Maybe look at the trailer connector to see if it is skinned up and shorting/grounding out, just not enough to blow the fuse. Inside right rear behind tail lamp.
Old Jul 25, 2012 | 11:18 PM
jfall's Avatar
Here is one more step to dovetail with Savanna's excellent advice..
I would take the same meter you have used..
Pull OUT the tail light light bulb.
Put the red or (+) in the socket where the tip at the bottom of the light would go.
That will be a small solder circle right in the middle.
Put the (-) end to a bolt or frame as before.
Then turn on the tail lights.
See if you get a 12 volt reading.
If you do then good.
That would mean you have a bad ground along the way.
Someone may have also put the wrong light bulb in there.
Or the light bulbs are bad.
You can put the meter to OHMS x10 and put the meter across the light bulb -
one lead to the side case. One lead to the tip on the bottom of the light bulb.
The meter should go to almost 0 ohms if the light bulb is good.
If bad - the meter will not MOVE.
Old Jul 30, 2012 | 12:48 PM
Ok, I figured out the issue. I'm a moron, I had installed a new bumper rendering my indicator lights useless. I then re wired my indicator lights to work in the upper tail light, not even realizing that it would disable my tail lights. This past weekend I re wried everythingt basck ot normal it it all works. I had ot buy a couple little trailer turn signals that i'm not too excited about but they will do for now.
Thanks for all your help with this.
Old Jul 30, 2012 | 06:54 PM
wilson96rr's Avatar
Maybe this will help you out. On my 03 Disco, I installed upper tail lights from a 99-02 model because I don't like the look of the yellow 03 lights. I used the back-up light socket to do the turn signal lights. I just installed an orange bulb in place of the clear one. I left the tail lights and brake lights alone. In your case, you would just lose your reverse lights which can easily be mounted on the bumper or a roof rack. Just an idea.
tsuyoi
Sep 22, 2020 10:37 AM
zigzag3141
Apr 13, 2017 12:47 AM
kumbhani123
Nov 18, 2009 07:23 AM
kumbhani123
Nov 17, 2009 05:36 PM
chrisandsarah
Nov 30, 2007 03:35 AM
