Taking heads off this weekend, exhaust manifold bolt concerns
Old Aug 8, 2014 | 03:49 PM
  #31
acamato's Avatar
Originally Posted by RicketyTick
You can also pay a deposit to rent one from autozone and get all of your money back when returned. just an option.
I will ask when I return their thread chaser kit.
Old Aug 8, 2014 | 03:53 PM
  #32
acamato's Avatar
Originally Posted by drowssap
well at least you will know it is right going back together
Very true, my original plan was 1 week. That went to two weeks because of the cam and the shop doing the heads was backed up. Then to three weeks because of the springs. The springs shoud be delivered to the shop Wednesday.
I almost ordered the kit (lifters, springs, retainers and seals) when I ordered the cam. I figured I could save some $$ by just getting the lifters. That worked out really well. If I did order it, I would have saved 1 week and some $$.
Old Aug 11, 2014 | 10:26 AM
  #33
acamato's Avatar
Didn't get as much done as I wanted to this weekend.
I installed the water pump, front cover, timing chain/gears and oil pump.
I also got the oil pickup installed.
I ordered some brass shim stock (.016 & .032) just in case I need to ship the rocker pedestals.
I am using .020 & 1/16" (.0625) brass rod to use as lifter preload go/no go gauges.
Old Aug 11, 2014 | 11:25 AM
  #34
drowssap's Avatar
you are using Crower cam, lifters, springs & retainers, I would go by there install directions rather than LR directions.
Old Aug 14, 2014 | 03:49 PM
  #35
acamato's Avatar
Springs were delivered to the shop yesterday afternoon. Got a call today, the spring pocket needs ro be machined from 1.2" to 1.4" and down 0.065" to get a seat height of 1.7". More $$. We said that SBC springs would work with the crower retainers and wouldn't require machining. He was concerend about going down in the seat because he has had experience of hitting water jackets on alum heads.
I told him I will take the chance. I decided to go with the crower springs. If I ever had a issue, Crower couldn't say it was becuase I used another spring.
Old Aug 14, 2014 | 04:39 PM
  #36
drowssap's Avatar
you should put a shout out to anyone else using that cam and see if it was required of them. only because that kind of takes it out of the bolt-in cam category,
Old Aug 14, 2014 | 05:50 PM
  #37
RicketyTick's Avatar
I think I remember someone here using Crower cam, springs and retainers not too far back and don't remember any mention of machine work for the springs...... Can't remember who though?
That would be good to know. I had been considering that setup assuming it was a bolt in.
Old Aug 15, 2014 | 07:08 AM
  #38
acamato's Avatar
wallyman424 has the Crower 50229, lifters, springs and retainers. I did PM him and he needed to have the valve springs seats modified.
The 50229 cam and lifters are bolt in. WHen I found out I needed new springs, I decided to get the Crower springs. I didn't realize that the spring seated needed to b modified. If I know that I would have bought stock springs.
I also found a posting about building a stroker and they used Crane 99849 small block Chevy springs. Affordable Aluminum Buick / Rover Stroker Motor, by Kurt Schley These springs are the same OD as the stock rover springs.
Old Aug 15, 2014 | 07:37 AM
  #39
drowssap's Avatar
I love that post Affordable Aluminum Buick / Rover Stroker , it should be re-named how the make your machinist rich.
300 Buick crank,
ford pistons,
GM wrist pins,
VW retainers,
GM mains and rods,
Pontiac valves.
there has to be at least 2-3k in machine work alone.
and they don't even address liners.
I assume that article is quite old at this point.
Old Aug 15, 2014 | 10:24 AM
  #40
acamato's Avatar
Just got off the phone with the shop. He wanted to confirm what I wanted to do. After talking with him some more, I changed my mind. I am going with chevy small block springs. They will have a 94 lb seat pressure. More than the stock springs 76 lbs, but less than the Crower springs, 104 lbs.
Its $190 cheaper to go with the chevy springs. Crower Springs and retainers ($171 - 15% restock fee) and save $80 on the spring seat machining. The springs are only $36.
