Taking heads off this weekend, exhaust manifold bolt concerns
Old Sep 22, 2014 | 02:30 PM
  #51
acamato's Avatar
Not too happy. Ran the DII for a 20+ mile trip when I got back home I smelled coolant. Hoping it was a leaking hose. I opened the hood and found the expansion tank venting.. I let it cool down and checked the coolant level. I didn't lose any. Oil is clear.
Things I plan to do:
- swap expansion tank cap with one from my parts DII
- combustion gas test (if it fails, I will pull the intake and valve covers and torque the head studs to 100 fl lbs from the 75 when in install them)
Old Sep 22, 2014 | 03:09 PM
  #52
RoverMasterTech's Avatar
I'll give ya tree fiddy for it.
Old Sep 23, 2014 | 07:16 AM
  #53
drowssap's Avatar
i would pressure test the cooling system looking for a leak before i started checking for CO@ in the coolant. you did say you could smell coolant.
Old Sep 23, 2014 | 07:48 AM
  #54
acamato's Avatar
I will do that. I am not losing coolant. I think what I smelled was the vapor venting out of the expansion tank.
After I did the heads, my throttle body cooler leaked. I ended up bypassing it.
Old Oct 20, 2014 | 08:49 PM
  #55
coors's Avatar
What was the cause of your coolant leak? Did you ever get it sorted out?
Francopacks
Feb 15, 2023 07:08 PM
SemperFiDisco
Jan 31, 2013 06:01 AM
twaszak
Jul 15, 2012 07:21 PM
Rearden Steel
Jul 12, 2011 08:37 AM
fridgefreezer
Mar 3, 2007 10:42 AM
