TB Heater question.
Old Sep 19, 2013 | 01:26 PM
sDot's Avatar
Default TB Heater question.
I was just wondering if I was to bypass my throttle body heater, would I need to also block off the tb heater itself?
Old Sep 19, 2013 | 05:16 PM
Nope. But if you operate where it can get close to freezing be aware that throttle can ice and stick in a fixed position.
Old Sep 19, 2013 | 05:42 PM
br0keit's Avatar
I just went through myself last week. I bypassed it TEMPORARILY while I waited for parts but found that leaving it bypassed all the time (especially if you live where it can get cold) is a very bad idea.
I would rather spend $25 than risk going full throttle off a cliff.
It seriously take 15 minutes to change. It is 7 tiny bolts. Take off TB, replace heater, reattach TB (with new gasket of course), done.
Old Sep 19, 2013 | 10:26 PM
It is not much risk in Washington DC, all that hot air inside the beltway.....
Old Sep 19, 2013 | 11:44 PM
suzukisam967m's Avatar
no other car freezes why would a rover? I bypassed mine when it leaked. you can just run one hose into the manifold where the other hose comes out.. and then you only need one hose
Old Sep 20, 2013 | 08:36 AM
sDot's Avatar
I replaced my TB heater, but I think the screws it came with were very cheap and didn't feel sturdy when i put them in, so I am seeing it leak again. I want to remove the TB and maybe pick up some better screws and get it tight again. It was great for the last 6 months and now it is leaking. Just want to know I can bypass it temporarily if needed.
Old Sep 20, 2013 | 08:50 AM
drowssap's Avatar
run a file across the bottom of the throttle body to make sure is level, also.
ls1morethanyou
Jan 12, 2017 10:21 AM
LR03NJ
Dec 6, 2010 07:03 PM
MBD506
Dec 7, 2009 03:02 PM
AK Rover
Nov 13, 2008 11:42 PM
AK Rover
Aug 24, 2008 05:57 PM
