In tears over 03'
Old Aug 12, 2010 | 10:57 PM
snowdude's Avatar
Default In tears over 03'
oil warning light intermediate, cant afford new engine. I dont want to sell it, butIi can't see how I can keep it!!!
I guess this is the "Love - Hate"
Old Aug 12, 2010 | 11:15 PM
bosshogt's Avatar
What about starting with this or this. How can your be sure the engine is done?
Just dont drive it and check the oil pressure.
http://www.roverparts.com/Parts/8979.cfm
http://www.roverparts.com/Parts/ERR6438.cfm
I know two people that own a 2003 that replace their front cover and their engine is back rolling again. Have faith it may not be the end
Old Aug 13, 2010 | 12:25 AM
Camdisco24's Avatar
ahh man that really stinks. Hopefully you can work something out.... Getting rid of a Disco when you dont really want to would be rough on me...
Old Aug 13, 2010 | 07:41 AM
sloan74's Avatar
x2 check the oil pressure. the tool is under 20 bucks and very easy to use.
________
Marijuana Hemp
Old Aug 13, 2010 | 08:24 AM
ShortTom's Avatar
Sorry to hear that snowdude.
Not to highjack the thread, but what's the cheapest solution here, assuming it is an oil pump failure? A used '04 4.6? Is that a strait swap? Or is a rebuild with a new non-screwed up 03 block the better way to go? For extreme cheapskates (such as myself) is it possible to remove the engine, replace the pump and reinstall the engine and be all good for another 30k or something?
My 03 is in the VIN roulette range.
Old Aug 13, 2010 | 10:13 AM
ShortTom's Avatar
SNOWDUDE!
Check it:
http://cgi.ebay.com/ebaymotors/ws/eB...tchlink:top:en
If I was in your shoes I might do this. It's an 04 4.6 with 136k on it (not so great mileage) and needs a HC for $699 OBO. Before you put it in you could repair it and do the major stuff and probably be at $1500 or so. Still a lot, but more reasonable than $3-5k.
Comments please! I might do this myself if/when the fatal day comes...
Old Aug 13, 2010 | 10:35 AM
Mark G's Avatar
You solution is simple:
1) Used engine (I've bought many over the years, never been burned).
2) Install it yourself, or with a buddy. No mechanical skills? Well, necessity tends to push folks towards practicing self-reliance. Get some tools, give it a try. Only thing standing in your way is your own self-doubts. This forum is a great helping tool.
Best of luck,
Mark G
Old Aug 13, 2010 | 11:03 AM
yloDiscoII's Avatar
cant afford new engine. I don't want to sell it, but I can't see how I can keep it!!!
Man that really sucks, I feel for you
IMO you should price it out the engine swap before you give up. It might be cheaper than selling your Disco for next to nothing because of the engine issue, then buying a replacement used car, then paying sales tax, title fees, etc,...
Old Aug 13, 2010 | 11:41 AM
sloan74's Avatar
It really boils down to how much time you have to invest and what kind of tools/garage you have access to.
For most 4x4 vehicles, engine swaps are #2 behind transmission swaps. transmission swaps are a pain...lol
Swapping the exact same engine should not be very hard. No welding, no new wire harnesses (this is the pain in the ***, $$$, if using a different engine). It would pretty much be unplug and plug. All you would just need is the cash for another engine and the motivation to do it.
You can rent a lift from Autozone to pull it out and put the other one in. The lift might even be free, u just pay a holding fee or something. Get yourself some air tools from Sears also to make it easier/faster. Have access to a few breaker bars and socket driver extensions. Have a buddy to help with the big stuff.
I bet you could knock it out in a weekend and save thousands, plus walk away knowing A LOT more about your rig than you did before. Start a thead before you start and picture and walk thru the process, make yourself famous on the Land Rover Forums.
I would shop for a wrecked rover (I see a lot of them on craigslist). You could strip the engine, put it in yours, then strip the rest of it, clean the parts, and sell them out on craigslist over time (xfer case, transmission, seats, dash controls, sensors, switches, etc. You might even break even in the long run.
________
Sativa strains
Old Aug 13, 2010 | 05:29 PM
Bryan H's Avatar
I've swapped an '04 engine into my '03. It's pretty straighforward plug and play. Maybe not as easy as one would hope, but it'd doable. Took me about 3.5 days of pretty hard work. I could do it faster now, but you're bound to have several things come up that easily waste 1/4 of a day.
