tech help
Old Jun 25, 2010 | 09:08 AM
jhulk7855's Avatar
6th Gear
Default tech help
Can someone tell me why a disco 2 will not start? other than the battery, i have a 1999 disco 2 and i can not figure out why it will not start. It has 130,000 miles, it just seems its something simple but cant figure it out.
Old Jun 25, 2010 | 09:13 AM
Bundu's Avatar
Banned
Have you checked the obvious stuff like gas, spark, does the starter turn the engine, etc? You need to be a bit more specific.
If the starter is turning the engine over and you have gas and spark and all else is good then the likely suspect is the crank position sensor.
http://www.roverparts.com/Parts/ERR7354G.cfm
Old Jun 25, 2010 | 11:27 AM
Is the engine turning over, just not starting? If so first reset your alarm, lock and unlock it 3 times. If that doesn't work, reset the inerita switch on the passenger fire wall. If it still doesn't start although the engine is turning over, then replace your Crank Sensor, pretty common problem.
16
Sep 24, 2014 08:10 PM
StevenDiscoII
Jan 2, 2007 07:05 PM
benjie
Dec 27, 2006 03:31 PM
SJT
Aug 29, 2006 08:26 PM
charlie0033
Aug 15, 2006 02:05 PM
