Sponsored by: CARiD
tech help plz
Old Dec 27, 2006 | 02:16 PM
benjie's Avatar
Default tech help plz
Hi-im hoping someone can give me some assistance on a range rover im working on at the moment-the manual i have is unspecific on a few areas eg1) the plug caps are unmarked and there is a 4 pin inline distributor at the rear of the engine in a very unaccomodating place-i need to know the order of pins to plugs as there are no marks.2) the manual says to do the camtiming, you need to horizontally line up the two timing marks on the cam pulleys-well there are 4!-1 inlet and 1 exhaust mark on each pulley-could someome enlighten me as to which marks to line up please. Any help would be greatly appreciated-cheers.
Old Dec 27, 2006 | 02:51 PM
Default RE: tech help plz
I am confused your your post, what year and model, how many miles on the truck and what is the truck doing wrong or are you wanting to do to it?
Mike
Old Dec 27, 2006 | 03:31 PM
benjie's Avatar
the vehicle is a 1992 model with 4 pot lump long. not traverse. it came to me with one valve broken and head apart. have replaced the valve and put head back on-now need to finish rebuilding the engine which entails setting up timing, and also the plug problem before i can get her running. i couldnt tell you the vehicle model, just that its a range rover, but if such info is necc. to provide answers, then can find out tommorow-thanks !
nick731
Jul 1, 2008 05:35 PM
nick731
Jul 1, 2008 05:21 PM
02Disc02
Apr 22, 2008 10:09 AM
Bigmonty
Dec 20, 2007 04:34 PM
kumbhani123
Jan 30, 2006 03:24 AM
