tech help
Old Mar 28, 2007 | 07:47 PM
groundpounder's Avatar
Default tech help
Could a brother get his Disco brethren to lenda helping hand? Probably should have dropped the original thread here...
https://landroverforums.com/m_24708/tm.htm
Thanks, boys!
Old Mar 29, 2007 | 12:50 PM
BogdenZ's Avatar
Default RE: tech help
Sounds like you've got a fuel delivery issue. I'd start with the small stuff like fuel pump fuse/relay. If you're good there, move on to the filter and, ultimately, the pump.
Unfortunately, where you said it's been running rough for a couple of days and with the age and mileage,it sounds more like a pump than a filter. A pump will usually give you the types of warning signs that you got (stumbling, etc.) and, ultimately, go dead. Even if a filter is badly clogged, it'll often allow enough gas through to intermittently fire the engine.
Go easy on attempts to start it. If your pump's gone, it's not going to happen.....and you'll do a number on your starter.
Old Mar 29, 2007 | 01:23 PM
Aquaholic's Avatar
The sure way I know to tell if your fule pump goes out is that it's always right after you fill up. That way you have a ton of gas to drain out before you remove the tank - I think it's one of Murphy's laws.
Old Mar 29, 2007 | 01:25 PM
okdiscoguy's Avatar
That is a fact. I filled up my old Suburban with 42.7 gallons, and made it home. It went out in the driveway (thank goodness) but I had to drain most of the 42 out. I filled up 3 of my other cars from it. Murphy.....
Old Mar 29, 2007 | 02:02 PM
BogdenZ's Avatar
Actually, you may have a good theory there......given that pumps overheat when the fuel level gets too low to keep them submerged/cooled by the gas, it makes sense thatsomeone would be in need of afull-tank fill-upright around the time that their pump's on it's way out.
Then again, it's probably not worth trying to make sense of Murphy's Law!
Old Mar 30, 2007 | 02:32 AM
ORIGINAL: BogdenZ
I hear ya. I'm not one of those guys who says, "Maybe if I just keep spinning it over it'll finally catch on!" Nope, not me. We need three things to run: fuel, air and spark. They have to arrive at the party just about the same time. If you ain't running, one of them is a no show and rolling it over ain't gunna change it.
Old Mar 30, 2007 | 10:55 AM
Aquaholic's Avatar
If you've got a helper to crank it see if it will run on starter fluid - that's a pretty easy way to see if it's a fuel issue.
16
Sep 24, 2014 08:10 PM
StevenDiscoII
Jan 2, 2007 07:05 PM
benjie
Dec 27, 2006 03:31 PM
SJT
Aug 29, 2006 08:26 PM
charlie0033
Aug 15, 2006 02:05 PM
