Tell Me I'm Wrong:
Old May 13, 2020 | 03:02 PM
CollieRover's Avatar
That’s awesome Best.
Old May 13, 2020 | 04:51 PM
The Deputy's Avatar
"Tell me l'm wrong"
That's your wife's job, not ours...lol.
Normally, they do it with such great joy.
Old May 13, 2020 | 05:24 PM
Best4x4's Avatar
haha
Old May 14, 2020 | 12:16 PM
Spam2021's Avatar
I'm very interested in this as well. Does the LR3 pump produce more pressure than the stock D2 pump? I feel I have a bit of trouble turning larger tires while off road during slow speed driving.
Old May 14, 2020 | 01:14 PM
Best4x4's Avatar
Not sure about the pump specs vs a D2, just something I wanted to look into and experiment with.
I did however order a replacement D2 PS pump for my friend and I was pleased to see that flimsy gasket that always leaks was replaced with a much more stout looking seal/gasket.
Old May 14, 2020 | 10:31 PM
Bignacio's Avatar
Hey Best, If I have to order a ps pump down the road( in case the LR3 one doesnt workout) what pump would you recommend with that better gasket? Thx...
Old May 15, 2020 | 12:24 AM
Best4x4's Avatar
It was a pump off of ebay actually. I'll see if it had a brand name. It was new vs refurbished.
Old May 19, 2020 | 12:59 PM
TimInNova's Avatar
I wonder if this GM pump swap would work on a Disco 2:
Converting your Classic to GM power steering pump
Old May 19, 2020 | 07:54 PM
Extinct's Avatar
The biggest issue on D2 pump is the integrated compressor bracket. There was an S10 pump one of the D1 guys found worked well on his D1, I tried it on the D2 but it was too wide to fit in the bracket (same bolt pattern). I was not up for the modification work necessary at that time. I actually do not hate the ZF pump that much. The gasket in the back is the weak point, followed by the fact they used a sealed bearing at the front that wears out after a couple hundred thousand miles. Both are replaceable and the pump is rebuildable. Nothing else in it wears out.
I will be interested to see how the LR3 pump works.
Old May 21, 2020 | 09:25 AM
Is the LR3 pump more powerful? Or is the benefit it is more reliable?
