Tell Me I'm Wrong:
Old May 21, 2020 | 09:41 AM
  #21
Brandon318's Avatar
Subscribed. I'm due for a replacement pump on the 2002.
Old May 22, 2020 | 09:19 PM
  #22
Best4x4's Avatar
Well the pulley diameter of the LR3 to D2 pump is the exact same minus it's a 6 grove vs a 7 like on the D2 (I tried to source a pulley to swap over, but that will require more research). The mount is different because the LR3 pump mounts are wider, but it could be made to work if you cut off the back of the OEM mount. The center stud would still go into the head so the outer 2 would just secure it to the bracket in the same fashion except they wouldn't pinch it into place anymore. I don't think there would be any more stress as the stud going into the head would remain unchanged. I'll mess with it some more when I get a chance, but I'm just out of time right now and I wanted to update everyone. The connections were identical as well for the hose and high pressure line.
Old May 23, 2020 | 03:39 AM
  #23
JUKE179r's Avatar
Cheers mate for the update!
gundog
May 8, 2014 07:03 AM
er1c
Jan 22, 2014 11:57 PM
Rferguson
Aug 19, 2013 09:51 AM
thehulk
May 8, 2010 10:35 PM
RWDRIFT
Mar 11, 2010 06:13 AM
