Tennessee Disco II Support
Old Nov 7, 2010 | 08:10 PM
Seanqwood's Avatar
5th Gear
Default Tennessee Disco II Support
I am a new Land Rover owner. 2001 Disco II with 92,000. I am performing Mikes servicing this weekend along with replacing the MAF, plugs and wires, and O2 sensors. I have the CEL for 0171, 0174, 1171, 1174, 0733, 0734, and 1590. I am looking for a recommendation for help in the Nashville area with knowledge of Rovers (other than the dealer). Can anyone recommed an ABS reader? The Amigos will be handled next weekend.
Old Nov 7, 2010 | 08:13 PM
Seanqwood's Avatar
5th Gear
I am going to order the ABS Amigo. I am still looking for someone in the TN area with knowledge.
Old Nov 7, 2010 | 10:14 PM
hilltoppersx's Avatar
did you do your head gaskets yet? are you losing coolant?
Old Nov 8, 2010 | 08:04 AM
Seanqwood's Avatar
5th Gear
The head gaskets are fine as far as I can tell. The coolant level has not changed. I will continue to monitor. Should I consider a HG replacement as preventative maintenance?
Old Nov 8, 2010 | 08:22 AM
take the VIN and call a dealership and get the service history. They might have been done already at a dealer or an indie shop. Tackle the maintenance list, get the codes cleared and then if the CEL comes back on get the codes read and come back with what codes are left.
don't do the head gaskets as preventative. wait till they are a problem.
have you checked out the front driveshaft? check to see if it has been rebuilt with greasable U-joints. If not that should be a priority. read this https://landroverforums.com/forum/sh...ad.php?t=29302
Old Nov 8, 2010 | 09:31 AM
yloDiscoII's Avatar
In Hendersonville - http://autosmithtn.com - Took my DI there once, they were alright.
In Franklin - http://edsbritish4x4.com/
There used to be an independent Rover shop on Myatt drive close to Rivergate Mall that I took my DI to, but I can't find it with a Google search, and don't remember the name of the place.
Old Nov 8, 2010 | 11:57 AM
Seanqwood's Avatar
5th Gear
Thanks for the help guys. I will post after the weekend projects are done.
tdefur
Dec 15, 2013 06:05 PM
Jd4d
May 16, 2011 01:58 PM
Pickup Man
May 16, 2011 10:48 AM
BelaFontaine
Dec 1, 2010 02:43 PM
rwp389
Jan 21, 2008 04:38 PM
