Terrafirma Bumpers
Old May 9, 2017 | 11:25 AM
Motorhead1's Avatar
I think it's bs, you spend that much money for a product, it better fit or I would be shoving it up someone's yeah...This makes me not want to purchase TF bumpers.
Old May 9, 2017 | 11:33 AM
Jeff Blake's Avatar
It is BS. And they give you Grade 5 bolts of wrong length and don't fill the bolt hole.
The actual bumper is very well made though. It's the only low profile one out there that accommodates a winch. The washer bottle guard is a nice bonus as well.
Old May 9, 2017 | 12:09 PM
Motorhead1's Avatar
A friend of mine has the low profile one on the front of his rig, he did the install about 4 years ago, back when you could get one for like 499.00 or something...his install went well from what I remember. He was just nervous about having to cut the plastic grill. It's a great looking bumper
Old May 9, 2017 | 01:17 PM
Jeff Blake's Avatar
I got mine for under $500, I think it was $550 shipped.
Making progress... I just MIGHT be able to get this thing on without cutting off parts!
When you put it on and start hammering it on, then take it off, you can see the high spots where the paint is chipping off the bumper... grind down corresponding spot on frame. Rinse repeat
Old May 9, 2017 | 09:29 PM
Jeff Blake's Avatar
Got the mother****er installed without cutting off anything!
Took about 8 hours across a few days, a couple dozen test fits, angle grinder and dremel, 2 bottle jacks (vertical and horizontal), pry bars, and god knows what else I used. It was a mess. There's no way the bolt holes will line up, so my strategy was to at least align one end of each bolt hole, then ream it out with a 1/2" drill. Tomorrow I'll tighten her down and drill for the vertical bolts.
Old May 10, 2017 | 01:08 AM
abran's Avatar
After only 2 bottles of jack? I would have drank a whole case...
Old May 10, 2017 | 11:05 AM
Best4x4's Avatar
Once I cut off the lower plates 90% of my issues went away! Then I spent maybe 15min bolting it up and I was then onto installing the Warn M8000 & cutting the grill support bar.
My frame was as smooth & straight as it could be and without the lower plate removed there was a NO WAY it was going to bolt on.
disco202
Mar 22, 2021 10:06 AM
wheelgarage
May 10, 2012 11:39 PM
newb
Appearance & Camping Set Ups
Mar 11, 2006 06:01 AM
disco12
Jan 10, 2006 09:50 PM
Ray
Nov 14, 2005 09:34 AM
