Terrafirma Steering linkage
Old Mar 10, 2016 | 10:46 AM
bmeier's Avatar
Default Terrafirma Steering linkage
Anyone running the terrafirma track rod, draglink assembly and panhard rod on their D2? Worth the money? I'm about to pull the trigger on replacing my steering linkage.
Old Mar 10, 2016 | 11:16 AM
drowssap's Avatar
if you going off road they are worth the money, pretty meaty. not necessary for the street or occasional on & off. jmho
Old Mar 10, 2016 | 12:59 PM
Best4x4's Avatar
I'll be installing the TF HD steering setup very soon. My OEM stuff is finally worn out at 225K. I didn't get the adjustable Panhard Rod, but I do plan on it as with my 2inch TF Lift the axle is slightly off centered.
I priced OEM MOOG stuff, and by the time you get it all you're not that far off from the TF HD setup. From what I've read the TF setup uses RRC replacement Tie Rod ends.
Old Mar 10, 2016 | 01:38 PM
acamato's Avatar
How's the TF compare to the Rovers North Heavy Duty? STEERING ROD SET HEAVY DUTY DISCOVERY II PLS006HD, TF255 - Rovers North - Classic Land Rover Parts
Old Mar 10, 2016 | 02:15 PM
ZGPhoto's Avatar
Essentially the same pieces except the TF will have better corrosion resistance and the bracket isn't welded on.
Old Mar 10, 2016 | 09:27 PM
Charlie_V's Avatar
I have the HD adjustable panhard, drag link, and steering arm from TF.
I like them except for two things. First, the steering arm uses grooves and u bolts to hold the steering stabilizer. Not the best setup (my OEM one had a welded bracket). A small amount of torque on the nuts broke one of the u bolts. I got better ones and it has been fine since then. Then the adjustments in the ends of the drag link and steering arm come loose sometimes. I can't get them to stay.
Very heavy though. Feel like they could take alot of punishment.
I've probably had mine a year, maybe more, and they are holding up very well.
Old Mar 11, 2016 | 01:29 AM
bmeier's Avatar
How often would you say the drag link ends come loose?
Old Mar 11, 2016 | 07:59 AM
Charlie_V's Avatar
Basically every time I check them; maybe once every couple of months (when I change the oil and grease the driveshafts). The drag link has not extended or retracted and changed my alignment but the locking nuts just don't stay tight. I tighten them with wrenches then, a few weeks later, I can turn them with my hands.
The steering bar has the same setup for adjustment. Same issue. Almost every time I jack up one side of my truck, which is pretty often if you see my other threads, the steering is off a tad when I am done. But in normal driving it doesn't move.
Old Mar 11, 2016 | 09:47 AM
Alex_M's Avatar
Charlie, have you tried some loctite?
Old Mar 11, 2016 | 10:06 AM
binvanna's Avatar
This kit is much stronger: 3/4" Heim Steering Kit - RuffStuff Specialties or you can consider their advice and bore your knuckles out to 3/4" and use the 7/8" kit which is even better.
