TF 3" Lift: Is my stock driveshaft going to explode?
Old 01-23-2017, 03:52 PM
BimmerDawg's Avatar
Default TF 3" Lift: Is my stock driveshaft going to explode?
Talking about the front here: I've been reading old threads for a half hour and can't seem to get a definitive answer. Yes, I know it's recommended, but is it 100% needed? Also, when it fails, is it catastrophic, or will a vibration get progressively worse? And yes, I'm being cheap. I paid $500 for it, LOL.
Old 01-23-2017, 04:04 PM
Jeff Blake's Avatar
The stock driveshaft is pretty strong, but you're problem is going to come from the fact that the stock driveshaft doesn't have greasable u-joints, and this is a problem regardless of the lift. If you don't rebuild it with greasable joints (and remember to grease them!) or get a heavier duty DS, then the driveshaft will eventually knock a hole in the transmission.
BimmerDawg (01-23-2017)
Old 01-23-2017, 04:16 PM
BimmerDawg's Avatar
Okay that makes sense. Is the Lucky8 one good enough you think?
Old 01-24-2017, 08:05 AM
LR03NJ's Avatar
Lucky8 have those and the heavy duty ones they sell are Tom Woods. A lot easier to grease beause the points are at the end of the bearing not in the middle where you can hardly reach.
BimmerDawg (01-24-2017)
Old 01-24-2017, 09:08 AM
Alex_M's Avatar
I'm on 3.5" lift with the lucky 8 shaft. No complaints thus far.
Just For Fun
06-10-2019 07:31 PM
jycsalas
05-23-2019 03:02 PM
jamieb
04-02-2016 10:33 AM
TheWhiteRover
09-12-2014 08:57 PM
wvcox1
09-12-2007 05:25 PM
Quick Reply: TF 3" Lift: Is my stock driveshaft going to explode?
