Is there a clutch in the window regulator ?
Old Aug 14, 2018 | 06:07 PM
Externet's Avatar
Question Is there a clutch in the window regulator ?
Hi.
The glass was left one inch from bottom; with my arm pushed it down with not much force by accident and the driver window stopped working. Did hear the motor not stopping. Reversed direction briefly to stop it, and did.
Removed the whole thing; the mechanism is like new, nothing worn/rusted/bent, rollers fine and lubricated.
Powered removed, all the regulator moves just fine. Reinstalled, has no force to move the glass. Is there a clutch inside the motor gearcase that gave up ? Is the clutch adjustable ? Do I have to replace the gearcase, the motor, both as an assembly ?
Edited: Found the problem. There is no slip clutch. The gearcase couples the output gear with a cheap black plastic wheel. Broken.
Anyone with a burned motor behind the spider webs that I can buy the gearcase?
cybercop
Aug 9, 2015 02:42 PM
ralphobell
Jun 24, 2012 08:37 AM
Robover01
Dec 27, 2009 10:31 PM
david1289
Mar 30, 2009 10:28 AM
