Is there some unwritten rule...
Old Oct 7, 2012 | 03:05 PM
Racer X's Avatar
Default Is there some unwritten rule...
...that Rovers have to leak something, no matter what? lol
The coolant pipe from the lower intake to the upper radiator hose assembly... either the O-ring or the pipe. I ordered both, just in case.
And why is that pipe so expensive?! Is it made from unobtanium or something?
/rant
Old Oct 7, 2012 | 06:28 PM
ZGPhoto's Avatar
As an old saying for Series Rovers, "If it's not leaking, it's empty"
Old Oct 8, 2012 | 10:51 AM
You have forgotten what your driving, they are not cheap to repair.
Have you ever replaced your upper hose, where is the bleed screw located, if on a tee, that is good, if molded into the rubber hose, you should replace it also because of the high failure rate.
Old Oct 8, 2012 | 12:00 PM
Racer X's Avatar
Trust me, my memory is as sharp as a tack. Just sucks that the same part is 28 quid from vendors in the UK, versus $105 from the only vender that sells the part new here in the US.
I also ordered the upper hose set for the reason you mentioned. $60 for the 3 upper hoses and a specialized T fitting isn't terrible.
utah95
Feb 14, 2014 08:47 AM
Hyakku
Sep 13, 2010 09:44 AM
StormTroopa
Nov 28, 2009 06:45 AM
