thermostat
Yup. Remove the old one and install the new one.
With the engine cold remove the upper radiator hose from the goosneck.
Unbolt the two bolts and scrap off all the old gasket material. Make sure that you mark the way the old one was facing so that you install the new one the correct way.
Install new t-stat and gasket, replace upper radiator hose, top off the coolant and check for leaks.
15 min job.
190 is the temp you want, so when you buy a new one from your favorite autoparts store that is the one you want. If it doenst list the temp then you want the high temp one.
Low temp is 160, med 180, high is 190.
15 min job.
MONTANACW
02-02-2007 01:22 PM
