thermostat
Old Aug 29, 2008 | 03:53 PM
ryanljcom's Avatar
Default thermostat
Hello all.
Any suggestions on replacing a thermostat. 96 disco.
Thanks..........
Old Aug 29, 2008 | 04:00 PM
Default RE: thermostat
Yup. Remove the old one and install the new one.
With the engine cold remove the upper radiator hose from the goosneck.
Unbolt the two bolts and scrap off all the old gasket material. Make sure that you mark the way the old one was facing so that you install the new one the correct way.
Install new t-stat and gasket, replace upper radiator hose, top off the coolant and check for leaks.
15 min job.
190 is the temp you want, so when you buy a new one from your favorite autoparts store that is the one you want. If it doenst list the temp then you want the high temp one.
Low temp is 160, med 180, high is 190.
Old Aug 29, 2008 | 04:02 PM
llesra's Avatar
im using a mr gasket 180 degree thermostat #4364
Old Aug 29, 2008 | 04:07 PM
I forgot to mention that when you retighten the gooseneck to tighten both sides evenly. Good and snug, not to tight, you dont want to crush the gasket.
If you use RTV or MR Gasket just make sure that read the directions.
Old Aug 29, 2008 | 04:08 PM
ryanljcom's Avatar
I went to auto zone and the guy sold me a duralast 195 deg. and a tube of permatex thermostat rtv silicone. What do you think..?
Thanks again.....
Old Aug 29, 2008 | 04:10 PM
Use it. Sounds like you are good to go.
Old Aug 29, 2008 | 04:14 PM
ryanljcom's Avatar
Thanks spike555.
You've been a great help last couple of days............
Old Aug 29, 2008 | 04:18 PM
Your welcome, thats whythe forum ishere, to help others.
MONTANACW
Feb 2, 2007 01:22 PM
EATMAN
Dec 4, 2006 05:14 PM
Disco.Jay
Nov 29, 2005 06:41 PM
II2Go
Aug 21, 2005 11:49 AM
mcanavan
Dec 9, 2004 05:42 PM
