Are these parts from rockauto good for replacing headgasket?
Old Jul 13, 2021 | 01:23 PM
evil_goat's Avatar
Question Are these parts from rockauto good for replacing headgasket?
I am replacing the head gasket on my land rover discovery 2004. If I buy a head gasket kit, and head bolts from rockauto.com, it includes most of the things from the atlantic british kit for half the price. The ones I found are both from the brand SKP. Here are the links to the parts:
https://www.rockauto.com/en/moreinfo...440627&pt=5416 (Head gasket with other gaskets)
https://www.rockauto.com/en/moreinfo...440627&pt=5308 (Head bolts)
Are they good to use and good quality? Do both of these kits contain everything I will need to replace?
Thanks in advance
Old Jul 13, 2021 | 03:38 PM
evil_goat's Avatar
Also are Victor Reinz head gaskets good?
Old Jul 13, 2021 | 04:12 PM
matt3502's Avatar
It really sounds like you are trying to do this HG project as cheaply as possible. I get that, but this is one of those situations where you want to do this right and do it once. You CANNOT re-use gaskets, oil or anti-freeze. I can state that there is a good chance you may have to replace other parts as you do this project like lifters, manifold bolts, etc. To give you a frame of reference my costs to do HG job in terms of parts and tools was about $800. My parts all came from AB, the exception being the injector filter basket kit and o-rings. The cost to have it done where I live was going to be at least $2500 for parts and labor.
The gasket kit from Rock Auto is missing the throttle body plate unit, the top intake manifold gasket, just at a glance.
Victor Reinz make good gaskets.
Old Jul 14, 2021 | 05:55 AM
XRAD's Avatar
I use VR head gaskets. They work fine and fit perfectly. I use ARP studs...not TTY bolts...
some of the kits like the AB kit are (were) missing correct parts (like O rings for coolant lines, TB gasket, etc...)
Old Jul 14, 2021 | 08:13 AM
logan_gibson's Avatar
https://lucky8llc.com/products/head-gasket-set-bolts
My go to set anytime I need to do a HG job.
After seeing your other post, it looks like you have more than just a HG job to tackle.
Old Oct 9, 2023 | 02:08 AM
4in6's Avatar
Default Victor makes good gaskets!!!!??? ???? ???? ???? No they don't
Ummmmmmm negative ghost rider. Victor aftermarket is not even close to OEM or fel-pro
Old Oct 11, 2023 | 10:52 AM
PickleRick's Avatar
I'm on my second set of vr gaskets. Had to do an emergency head gasket swap last Xmas Eve/Xmas afternoon and couldn't get the heads into a machine shop. Did what I could by working them on a concrete block like I was in a 3rd world village in 1920. Knew it wasn't a permanent fix but got me by.
The VR gasket lasted nearly a year before the warped head began passing compression past the fire ring. Didn't blow out the gasket but was stopped as soon as we heard the pfft pfft pfft. Pretty happy with it's performance. I used arp head studs. I did not loctite them in place as the heads do not pull up with them installed. TTY head bolts suck.
Old Oct 12, 2023 | 09:21 PM
Alex_M's Avatar
I've used more brands of head gaskets than I can count. Frankly, all have worked just fine. I get Fel Pro or some other big name if they're on closeout, otherwise I get the cheapest kit I can find.
Old Oct 14, 2023 | 12:30 AM
miron's Avatar
Just get Elring. They put them VW diesels and those run forever (as far as head gaskets are concerned). Btw, i was a total newbie when i replaced my gaskets and used a kit form AB and 40k later they are still there. I guess make sure you get the right thickness for your decked heads. Also the valley pan gasket comes in couple flavors and one that they sell as "premium" is actually worse than the cheap one. Lastly if you don't want to deal with a cracked oil pan get a oem oil pan gasket - i got a cheap one and it was missing one if the metal washer... pan cracked on the last bolt i was torquing.
evil_goat
Jul 12, 2021 05:57 AM
Matthew White
May 11, 2017 05:51 PM
Savannah Buzz
Jun 4, 2013 04:19 PM
brianb883
Jan 23, 2010 09:51 AM
wbstyles
Dec 14, 2008 01:00 AM
