Which of these two gaskets should I use?
Received 1,189 Likes
on
Probably on about the same level of quality. Just use a small bead of Permatex Ultra Black gasket maker on oil pan surface, about an 1/8 inch in diameter, going around each bolt hole, and along center in between, let sit for a bit until a slight glaze appears on gasket maker (maybe 30 seconds to a minute), install gasket on oil pan, then apply gasket maker to other side of gasket, using same technique, only this time, add a bit more around rear main area where main cap meets block and where front cover meets block, just a bit more, don't go crazy, install oil pan, let set up suggested amount of time mentioned in direction on ultra black's instructions, before adding oil.
