Which of these two gaskets should I use?
Old Jul 22, 2021 | 07:39 PM
Brandon318's Avatar
Default Which of these two gaskets should I use?
I’ve accrued two oil pan gaskets in my disco ownership, any one better than the other? AllMakes vs URO.
Old Jul 23, 2021 | 03:11 AM
The Deputy's Avatar
Probably on about the same level of quality. Just use a small bead of Permatex Ultra Black gasket maker on oil pan surface, about an 1/8 inch in diameter, going around each bolt hole, and along center in between, let sit for a bit until a slight glaze appears on gasket maker (maybe 30 seconds to a minute), install gasket on oil pan, then apply gasket maker to other side of gasket, using same technique, only this time, add a bit more around rear main area where main cap meets block and where front cover meets block, just a bit more, don't go crazy, install oil pan, let set up suggested amount of time mentioned in direction on ultra black's instructions, before adding oil.
Old Jul 25, 2021 | 12:55 PM
dswilly's Avatar
I got lucky and added the sealer only where the Rave manual indicated at front and back. So far leak free but time will tell. Be sure to torque in sequence as the Rave manual specifies.
abran
May 15, 2022 07:51 AM
Tony Luna
May 26, 2020 09:35 PM
MoShadeTree
Mar 9, 2012 03:46 PM
TBIAgent69
May 20, 2010 11:21 PM
David Kadasia
Apr 13, 2010 06:16 PM
