Those pesky coil packs
I just recently went through the nightmare of changing plugs and wires and going into the 3rd hour when the wire broke off into the coil pack so I had to remove it to pull the wire out I thought to myself, what If I relocated the coil packs.
Has anyone ever thought of it or has it been tired? What would be so difficult? I know you would need to extent the wire harness that leads to the coil packs but that isn't terribly difficult.
I mean, putting them anywhere but behind the motor to me is an option.
on
Don't waste your time, as already mentioned, they rarely fail and as long as you use good 8 mm silicone wires, you will only have to deal with the coil once. There are enough other issues with your truck that are more important to do, like dealing with your front drive shaft or doing a major service, to keep you busy.
meltdowndave
12-29-2009 01:54 PM
