Those pesky coil packs
Old Mar 16, 2012 | 07:48 PM
FlyingZebra34's Avatar
Default Those pesky coil packs
I just recently went through the nightmare of changing plugs and wires and going into the 3rd hour when the wire broke off into the coil pack so I had to remove it to pull the wire out I thought to myself, what If I relocated the coil packs.
Has anyone ever thought of it or has it been tired? What would be so difficult? I know you would need to extent the wire harness that leads to the coil packs but that isn't terribly difficult.
I mean, putting them anywhere but behind the motor to me is an option.
Old Mar 16, 2012 | 08:19 PM
dgi 07's Avatar
How much play in the harness do you have? That would be the main issue in relocating the coils.
Old Mar 16, 2012 | 08:42 PM
0304Disco's Avatar
Thought the same thing before. When you really look at the overall picture they are not a high failure item on the Disco. Pulling the Plenum to replace them does take additional time but its just the nature of the beast.
Old Mar 17, 2012 | 12:03 AM
well you could always hand make your wires (just takes some simple tools like crimps) and relocate it anywhere you want. And I know it isnt a high failure item but the hassle of it is just plain insane
Old Mar 17, 2012 | 07:31 AM
Don't waste your time, as already mentioned, they rarely fail and as long as you use good 8 mm silicone wires, you will only have to deal with the coil once. There are enough other issues with your truck that are more important to do, like dealing with your front drive shaft or doing a major service, to keep you busy.
trialrun
Nov 11, 2014 08:41 AM
MikeDailyDisco
Nov 21, 2013 04:47 PM
halfassedastronaught
Nov 22, 2010 11:45 AM
meltdowndave
Dec 29, 2009 01:54 PM
03discoman
Apr 27, 2009 09:54 AM
