Thread tap for secondary air ports in heads
Old Jul 26, 2016 | 03:44 PM
Jeff Blake's Avatar
Default Thread tap for secondary air ports in heads
Getting ready to pull the heads and reading ahead a bit on things I need. I like to follow RAVE as close to the T as possible... so I suckered up and bought 4 new secondary air adapters from Rover Jaguar Parts @ $55/ea.
In RAVE, it says to clean the deposits using a 5/8"-20 TPI UNF 2A thread tap, which of course I can't find anywhere online as 18 TPI seems to be standard. Anyone know where to get one of these... or should I just have the machine shop do it when I take the heads in to be planed and valves re-sealed? I'm guessing they'd have that tool, right?
Old Jul 26, 2016 | 04:46 PM
Racer X's Avatar
This will get the job done, but it ships from China and will probably take a couple of weeks.
https://www.amazon.com/Threading-Mac...s=5%2F8+20+tap
If you're pressed for time, or if you want the closest tolerance to the prescribed thread size and pitch, this is a good bet, albeit three times as expensive.
5/8-20 UNS, H3, 4 Flute, Bright Finish, High 04846143 - MSC
Good luck.
arahim93
Mar 10, 2016 11:11 PM
robersonb
Oct 31, 2015 03:37 PM
Perfectphoto
May 31, 2015 04:39 PM
oilspotLR
Feb 5, 2013 07:23 PM
DiscoWest
Mar 15, 2010 11:24 AM
