Three amigos: Replaced hubs and ABS sensor wire... still not fixed...
Old Aug 12, 2020 | 06:25 PM
Brandon318's Avatar
Originally Posted by COSitsWORTHit
also, could this be solved by option a or b fix at the modulator?
FWIW, the ABS block is new. Like, the $4K part. Additionally, wouldn’t the nanocom point me that direction if it was in need of work?
Old Aug 13, 2020 | 01:47 PM
Llamasayswhat's Avatar
DTC P1590
Rough road signal implausible Drive cycle A:Signal implausible.
Possible causes by suggested order of priority:
^ Connectors C504, ECM C637 (B).
^ Open circuit - C637/34 (RG) to C504/4 (RG).
^ ABS fault.
CONNECTOR
^ Check for connector not correctly latched, backed out pins, damaged pins, corroded pins.
Open Circuit - C637/34 (RG) to C504/4 (RG).
OPEN_CIRCUIT
^ Check resistance > 1M Ohm
ABS Fault.
CHECK THE FOLLOWING:
^ Carry out diagnostic checks on the ABS system.
POSSIBLE FAULTS
^ Faulty ABS ECU or wiring.
Old Aug 14, 2020 | 10:49 AM
Brandon318's Avatar
Update for those who care - Now the amigos are gone until I drive about 30 miles, then all but the HDC light comes on. I have a new ABS wire (the long, expensive one) from AB on it's way. We'll see if that kills them for good.
Old Oct 16, 2021 | 01:30 PM
Brandon318's Avatar
Was googling something else related to the three amigos and ran across my own thread that I forgot to close out. The new wire that runs all the way to the ECU didn't fix it. The thing that resolved the issue was replacing the hub yet again with a different, better brand. Hasn't come back since.
Old Oct 18, 2021 | 03:31 PM
cvhyatt's Avatar
What brand hub did you go with?
Old Oct 18, 2021 | 06:23 PM
Brandon318's Avatar
I don't remember the brand at the moment, but all the bad ones have been in Eurospare boxes.
Old Jan 12, 2022 | 07:54 PM
Brandon318's Avatar
Solved - Three amigos finally gone after taking out yet another Eurospare hub from Atlantic British and replacing it with an AllMakes hub from Rovers North.
Lesson to all future searchers: new parts don't necessarily allow you to rule them out when troubleshooting.
WarrenZ
Sep 13, 2019 04:39 PM
TheGeeker
Sep 17, 2018 10:16 PM
shady milkman
Mar 1, 2016 06:03 AM
vandal996
Feb 17, 2011 09:44 AM
fjaber
Jan 18, 2007 06:42 PM
