Threw a code... well... 15 at once
Old Sep 23, 2018 | 03:32 PM
robh's Avatar
Default Threw a code... well... 15 at once
I was driving along today and stopped at a red-light. Light turned green, I mashed the gas and truck started off, then lost power like the engine was going to stop, for less than a second but kicked back in, so fast the car behind me probably didn't even notice and I was able to pull away. I was thinking random misfire or something and everything was running normally.
Went into the store and came back out to find check engine light on. I assumed I was going to have a random misfire, no big deal, but found 13 confirmed and 2 pending codes:
P1884 engine coolant level lamp circuit
P1451 evap solenoid
P0414 secondary air switching valve “a” circuit shorted
P1482 cooling fan circuit condition
P0445 evap purge control circuit shorted
P0448 evap vent control circuit shorted
P0102 mass or volume air flow circuit low input
P0340 camshaft position sensor “a” circuit
P0135 o2 sensor heater circuit
P0155 o2 sensor heater circuit
P0141 o2 sensor heater circuit
P0151 o2 sensor heater circuit
P0154 o2 sensor no activity detected
Pending
P1451 evap solenoid
P0134 o2 sensor no activity detected
The truck has been running great other than my secondary air engine system howling occasionally at startup, so I think the blower motor is on the way out.
Any thoughts on what happened? I'm thinking electrical blip of some sort. Going to clean up the battery terminals and reset and hope for the best. And travel with a fire extinguisher in reach at all times
Old Sep 23, 2018 | 04:32 PM
Charlie_V's Avatar
P1451 evap solenoid
Pending
P1451 evap solenoid
The truck has been running great other than my secondary air engine system occasionally at startup, so I think the blower motor is on the way out.
I had a similar experience when one of the power (or ground, I cannot remember) cables that goes to the battery got loose and burned through the shielding on the exhaust manifold. When the bar wire contacted the exhaust my dash lit up like a Christmas tree, I then hit a bump and the whole truck went dead. In pitch dark I found the problem with my cell phone as a flashlight and used some zip ties to keep the cable clear so I could get home.
Old Sep 23, 2018 | 05:46 PM
robh's Avatar
Charlie_V ... you nailed it... an o2 sensor rewire got loose and melted on exhaust manifold.
Old Sep 25, 2018 | 02:20 PM
2Guinness's Avatar
Crazy, I had almost the exact same wire fire. Mine was a little worse as all the wires were in a single bundle and burned quite badly. Luckily the ones that burned through were long enough to cut and reconnect.
Old Sep 27, 2018 | 10:15 PM
Charlie_V's Avatar
Drivers side?
Glad to help, though I think I merely provided inspiration. I'm rarely right, haha... but a broken clock is right twice a day. The sun shines on a dog's a$$ occasionally. A bind hog finds an acorn. I'm the clock, dog, and hog.
Glad you found it. Are you going to re-insulate the wires?
erick846
May 14, 2020 12:55 PM
KlamathMatt
Apr 17, 2020 05:27 AM
KlamathMatt
Apr 9, 2015 08:58 AM
KlamathMatt
Apr 4, 2015 12:12 PM
mark 07
Mar 8, 2008 03:15 PM
