throttle body cleaning, 2001 D2
Old 11-27-2017, 03:57 PM
JoJo The Giraffe's Avatar
Default throttle body cleaning, 2001 D2
This was easy to do. Using CNC Throttle Bottle Cleaner, and placing a rag bellow the opening, a couple of sprays and cleanup with lint free cloths, did the job. I did manage to clean the contact area between the body and the gate, but only facing outward.
Is there a simple way of removing the throttle cables without the need of getting feeler gauges to reset them? I would like to get the job done right. Thanks for all comments.
Todd
Old 11-27-2017, 05:02 PM
Sixpack577's Avatar
Rotate the bracket on the throttlebody the cables hook to, clockwise. The cables will lift out after pushing the ends in or out of the bracket.
Old 11-27-2017, 05:38 PM
Best4x4's Avatar
Received 2,272 Likes on 1,676 Posts
Shouldn't ever need a set of feeler gauges to adjust the throttle cable/cruise control cables on a D2. You just adjust them with a pair of 13mm open end wrenches. I'd make each one sit about 2mm away from the plate. That way you'll have excellent throttle response and your cruise control won't surge.
Old 11-27-2017, 06:04 PM
By using my cheap plastic verniers, the outer cable plate (closer to you) spacing is 3-4 mm. The inner cable plate spacing is closer to 1 mm or less. There is not much rotation that can be had in order to remove the cables from the throttle body. The ends are in pretty good.
Old 11-27-2017, 07:04 PM
OK, got the wires off, the job is now finish. I think next year, Q-tips dipped in the cleaner should do going around the seam between the throttle plate and body. A rag just does not do the job.
Old 11-27-2017, 07:31 PM
Best4x4's Avatar
When I clean the throttle body I remove it completely from the D2 so I can clean it 100%.
Old 11-28-2017, 11:00 AM
CNC has a great website. Attached is a photo before cleaning. Don't know why I do not have an after cleaning photo, but the residue on your rags will tell the picture
OverRover (11-28-2017)
Old 11-28-2017, 11:37 AM
OverRover's Avatar
I think you are talking about CRC throttle body cleaner.
And in that case +1 for CRC products. They work very well especially the MAFS/TB and the Brake Parts Cleaner(Brakleen #091314)
Spike555
04-12-2016 12:28 PM
alemurill
01-18-2009 04:35 PM
avking
01-11-2009 09:05 PM
willrok13
10-14-2008 12:17 PM
bigugly82
10-15-2007 04:18 PM
Quick Reply: throttle body cleaning, 2001 D2
