Throttle Body Heater Kit Install
Old Aug 25, 2008 | 12:23 PM
rrhyne's Avatar
Default Throttle Body Heater Kit Install
I just replaced my seeping throttle body heater yesterday. Easy job, but I have a few questions:
Should have used some sort of Gasket Sealant?
What does that thing do exactly anyway?
(Mental note to self: ask these questions before installing part.)
Old Aug 25, 2008 | 01:50 PM
Default RE: Throttle Body Heater Kit Install
Yes you should have used a gasket.
The purpose of the the t-body heater is to keep it from iceing up in cold and high humidity.
Cold air is rushing past the t-body and it is REALLY cold in the winter, and when it is moisture laden it will form ice crystalson anything that it can. If it is bad enough it can cause the throttle to swtick open, or the engine to not get enough air.
Not a problem where it is warm, but they have no idea what you are going to do with your truck. Hell, you might drive it to the Artic Circle for all they know.
Does that answer your questions?
Old Aug 25, 2008 | 02:04 PM
rrhyne's Avatar
Spike, I did use a gasket... metal on metal general makes a poor seal.
I was wondering however, should I have used a little Gasket Sealant in addition to the supplied gasket?
Thanks for the info on what it does! hehe
Old Aug 25, 2008 | 02:41 PM
Ok, I thought that you did not use any gasket. A little RTV never hurts in my mind.
Old Aug 25, 2008 | 03:10 PM
rmuller's Avatar
7th Gear
the supplied gasket should be fine, it wouldnt have hurt to sand down the metal a little bit and clean it up.. but you should be ok with just changing it out..
Old Aug 25, 2008 | 03:18 PM
rrhyne's Avatar
I took a razor blade and scrapped the old gasket and gunk off, but I'll keep an eye on it.
Thanks guys!
aguison
Jul 15, 2014 03:57 PM
SenatorPerry
Jul 15, 2013 10:28 AM
ljdiscovery
Mar 4, 2011 11:10 AM
Rich 00 DISCO
Jul 3, 2008 09:09 AM
humroot
Mar 21, 2008 01:55 PM
