Ticking/clicking ABS Module
Old May 7, 2007 | 02:52 PM
RedElephant's Avatar
Default Ticking/clicking ABS Module
Hi,
There is something that is bugging me with my 03 Disco. The ABS Module is constantly making this ticking sound, even when the truck is shut down (no key in the ignition). The sound is very delicate and it's rather hard to hear, however in a quite place I can definitely hear it. There is no problem with brakes andABS as far as I can tell, no lights, no codes, no nothing. However, it still bugs me. I recently had the truck with the dealer for other reasons, and asked them to look at this as well. Obviously, they didn't even notice this. Finally, when I talked to their mechanic and had him listen again, he admitted he could hear it but didn't know what it could be.
I tried to remove some ABS related relays and fuses to see ifthe tickingwould go away. Per description on the fuse box lidunder the hood, I found 3 there. The first I tried was a big relay - it stayed. Then a fuse - the one in the middle row, rather biggish for a fuse, so maybe it's a relay as well. Still, it continued making its sounds. Finally, a small regular fuse on the passenger fender side, when I pulled it out, it went away. Put the fuses / relays back in and the sound is still gone - good. But after maybe an hour it's back, again, no starting or moving thetruck in between. Also, the big relay (the first one I pulled out) makes some little sounds as well, as if opening / closing a circuit all the time, I guess for the ABS module to do its clicking.
My questions to the forum are:
1.Does anybody remember hearing a similar ticking sound in his truck? Once again, it is very delicate andquiet sound, but in a quite garage you can definitely hear it with the hood open.
2. Could it be caused by failing wheel speed sensor(s)? Wrong pads / rotors contaminating them?
3. Is it ABS pump, and if so- can it cause premature wear of the module?
The truck has about 50K on the clock and doesn't look like it has ever been off-roaded. I am the second owner and just bought it about a month ago.
Sorry to bother everyone with this small thing, I know people have much bigger problems here.
Thanks,
Adrian
Old Feb 17, 2018 | 11:38 AM
nitram's Avatar
Hi,
I also have an 03 Disco and have noticed the same thing.
Have you been able to a address this issue?
Thanks,
Martin
Old Feb 17, 2018 | 11:58 AM
LR03NJ's Avatar
Originally Posted by nitram
Hi,
Thanks,
Martin
It ticks even when the engine is off
Old Feb 17, 2018 | 08:30 PM
Best4x4's Avatar
Every D2 I've ever been around or owned has done that. When I had an H3 Alpha I hung out with a few guys with H1's and their same exact Wabco unit did the same thing. I'd consider it to be normal IMHO.
Old Feb 18, 2018 | 07:53 AM
coors's Avatar
I’ve had two Discos MY01 & MY04 both (Waco’s) had the same symptoms. As mentioned above, even when the ignition is off. I never looked into why...
Old Feb 19, 2018 | 01:41 AM
Gripen's Avatar
My truck also does this. I figured it's normal for the model, though it does seem odd.
Mecevans
Aug 9, 2015 02:30 PM
mupmanyu
Mar 7, 2011 05:42 PM
domyo
Sep 25, 2008 12:19 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
